Dashboard process is not running - missing wwwroot
Product: PowerShell Universal
Version: 5.4.0 (13319778963) Nightly
I updated to a nightly build in lab, mostly cause i was trying to escape another issue. None of my apps start, they all fail saying
Could not find a part of the path ‘C:\Program Files (x86)\Universal\Modules\Universal\wwwroot\index.html’.
Which is true, the wwwroot is no longer present;
I copied a directory from another test , but that just got me to
System.ComponentModel.Win32Exception (2): An error occurred trying to start process 'C:\Program Files (x86)\Universal\Agents\5.1\Universal.Agent.exe' with working directory 'C:\ProgramData\UniversalAutomation\Repository'. The system cannot find the file specified.
   at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
   at PowerShellUniversal.Automation.JobProcessManager.StartProcessAsCurrentUser(String powerShellPath, String commandLine, Variable credential, Action`1 onAgentOutput, Dictionary`2 environmentVariables, String verb) in D:\a\universal\universal\src\PowerShellUniversal.Automation\JobProcessManager.cs:line 670
   at PowerShellUniversal.Automation.JobProcessManager.StartModuleDiscovery(ExecutionEnvironment environment) in D:\a\universal\universal\src\PowerShellUniversal.Automation\JobProcessManager.cs:line 537
   at Universal.Server.Services.ModuleService.Discover(ExecutionEnvironment environment, Boolean wait) in D:\a\universal\universal\src\Universal.Server\Services\ModuleService.cs:line 206
2025-02-17 18:22:12.735 +01:00 [ERR][PowerShellUniversal.Automation.JobProcessManager] Failed to check if process has exited.
This is also weird, i don’t have this path.
Edit: Also, trying to install the latest nightly build, it looks like it wants to do a clean install, saying it’s going to install the service. Normally it just updates.
All Comments (2)
This should probably be posted as an issue on Github, not here, since you’re using a version that isn’t meant for the general public. I could be wrong, though - maybe they want this here too.
