OnClick events not registering properly when element added dynamically
(anonymous user)
Product: PowerShell Universal
Version: 4.3.0
Hi all,
I have text input and a button. OnClick adds a new Element (div) to an existing div. The added element contains a Remove button to remove itself. I belive the IDs are set properly. However, after I add a second item the OnClick event of the first (or any previous) one does not fire. Any clues? I don’t think it’s a scope problem, as the elements in the DOM have correct IDs. Just the onclick events don’t work.
New-UDStack -Children {
    New-UDTextbox -id 'txtInput' -Placeholder 'placeholder'
    New-UDButton -Text 'Submit' -id 'btnSubmit' -Size small -ShowLoading -onclick {
        $inputValue = (Get-UDElement -id 'txtInput').value
        if (!$inputValue) {continue}
        try {$user = Get-ADUser $inputValue -Properties DisplayName -ea Stop} catch {
            Show-UDToast -Message 'User not found' -Duration 5000
        if ($user) {
            Add-UDElement -parentid 'container' -Content {
                New-UDElement -id ('item_'+$inputValue) -Content {
                    New-UDElement -tag div -Content {
                        New-UDIcon -icon 'user' -Size 1x -Style @{margin = '0 .8em 0 1em'}
                        New-UDButton -size small -id ('btn_'+$inputValue) -Text 'Remove' -onclick {
                            Show-UDToast -Message 'Removed'
                            Remove-UDElement -id ('item_'+$inputValue) -Broadcast -ParentId 'container'
                            Set-UDElement -id 'btnSubmit' -Properties @{Disabled = $false}
                        } -Style @{background = '#d92626'}
                        New-UDTypography -text ($inputValue+' - '+$user.DisplayName)
                    } -Attributes @{style = @{border = '.5px solid'; 'margin-left' = '4em'; padding = '.1em'}}
            Set-UDElement -id 'txtInput' -Properties @{Value = ''}
    New-UDElement -Tag div -id 'container' -Content {} -Attributes @{style = @{width = '50%'; 'margin-left' = 'auto'}}
} -AlignItems center
All Comments (4)
(anonymous user)
Dear @Adam Driscoll, may I request some assistance here? Thank you! L.
Issue not resolved even after upgrading to 4.3.4…
At this point i’d say you should concider reacing out to support
Ironman Software Support,
Or create an issue of it on github:
Issues · ironmansoftware/powershell-universal (github.com)
