4.2.14 Azure/Entra OIDC authentication issue
Resolved
(anonymous user)
Updated from 4.2.12 to 4.2.14, forms auth works fine. Apps startup fine and can get to them using forms auth. Attempting to authenticate to them using OIDC results in the following errors.
2024-03-27 08:03:28.082 -05:00 [ERR] Connection id "0HN2EBKSO5243", Request id "0HN2EBKSO5243:00000002": An unhandled exception was thrown by the application.
System.InvalidOperationException: IDX20803: Unable to obtain configuration from: 'https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxx/.well-known/openid-configuration'. Will retry at '3/27/2024 1:03:35 PM +00:00'. Exception: 'System.IO.IOException: IDX20804: Unable to retrieve document from: 'https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxx/.well-known/openid-configuration'.
 ---> System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 100 seconds elapsing.
 ---> System.TimeoutException: A task was canceled.
 ---> System.Threading.Tasks.TaskCanceledException: A task was canceled.
   at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.HttpConnectionWaiter`1.WaitForConnectionAsync(Boolean async, CancellationToken requestCancellationToken)
   at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
   at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
   --- End of inner exception stack trace ---
   at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts)
   at Microsoft.IdentityModel.Protocols.HttpDocumentRetriever.SendAsyncAndRetryOnNetworkError(HttpClient httpClient, Uri uri)
   at Microsoft.IdentityModel.Protocols.HttpDocumentRetriever.GetDocumentAsync(String address, CancellationToken cancel)
   at Microsoft.IdentityModel.Protocols.OpenIdConnect.OpenIdConnectConfigurationRetriever.GetAsync(String address, IDocumentRetriever retriever, CancellationToken cancel)
   at Microsoft.IdentityModel.Protocols.ConfigurationManager`1.GetConfigurationAsync(CancellationToken cancel)'.
 ---> System.IO.IOException: IDX20804: Unable to retrieve document from: 'https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxx/.well-known/openid-configuration'.
   at Microsoft.AspNetCore.Authentication.OpenIdConnect.OpenIdConnectHandler.HandleChallengeAsyncInternal(AuthenticationProperties properties)
   at Microsoft.AspNetCore.Authentication.OpenIdConnect.OpenIdConnectHandler.HandleChallengeAsync(AuthenticationProperties properties)
   at Microsoft.AspNetCore.Authentication.AuthenticationHandler`1.ChallengeAsync(AuthenticationProperties properties)
   at Microsoft.AspNetCore.Authentication.AuthenticationService.ChallengeAsync(HttpContext context, String scheme, AuthenticationProperties properties)
   at Universal.Server.UniversalDashboardStartup.<>c.<<Configure>b__5_0>d.MoveNext() in C:\actions-runner\_work\universal\universal\src\Universal.Server\UniversalDashboardStartup.cs:line 122
--- End of stack trace from previous location ---
   at Microsoft.AspNetCore.Diagnostics.StatusCodePagesMiddleware.Invoke(HttpContext context)
   at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionMiddleware.InvokeCore(HttpContext context)
   at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
   at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)
I uninstalled 4.2.14 and reinstalled 4.2.12 and the everything works correctly, can authenticate as expected with OIDC. Was there some change or something else in 4.2.14 is causing this?
Product: PowerShell Universal
Version: 4.2.12
Recommended Answer
Now that you’re on 4.2.13, I would try re-updating to 4.2.14 (if you didn’t already) to see if there’s potentially just an issue with jumping from 4.2.12 directly to 4.2.14. Sometimes upgrades need to be done in steps, so it’s worth testing it out to at least check it off the list.
All Comments (5)
Just to ask, did you try 4.2.13 to see if that has the same issue? We were using AzureAD as well, with 4.2.12 and 4.2.13 without any issues, and it’s still working fine with 4.2.14 for us. Looking at your output, it looks like a failure to download a file. Have you tried entering that URL into a browser on your PSU server after updating to 4.2.14 to see if it’s isolated to just PSU or if something else exhibits the same issue post-upgrade?
(anonymous user)
Blockquote
I just updated it to 4.2.13. It doesn’t have the same issue. 4.2.14 only seems to cause the issue. The URL works in a browser under both my account and the service account. I at first thought it was maybe some issue with the service account and the proxy setup but I verified it’s working. It seems to be just isolated to PSU.
(anonymous user)
Blockquote
I just gave that a try. That worked. I’m now not getting the error. I wouldn’t think that it’s that big of a jump but looks like going to 4.2.13 first is probably what I’ll need to do (I have other servers on 4.2.12).
Great. Glad that resolved your issue.
