PSU 4.0.12 Issue Create/Edit Schedule with GUI
(anonymous user)
Product: PowerShell Universal on IIS Server (Windows 2019)
Version: 4.0.12
Note : Issues created on GitHub
https://github.com/ironmansoftware/issues/issues/2659
I have an issue create/editing a schedule job with PSU Gui for Script using parameters. SomeBody could help me ?As soon as a script requires a parameter I get a 500 error.
Bug reproduction:
Create the following script:
param (
	[String[]]$tests
foreach($test in $tests){
    Write-Information $test
Create a schedule job with PowershellUniversal GUI
8bb8dc9033f35de1085ae353acef40d97d1ee23e
Result :
f47fcc30bdfb805556944e9946d7896382b8563c
Web error (developer mode) :
POST https://xxxxxxxxxxxxx/api/v1/schedule 500 (Internal Server Error)
Response : Object reference not set to an instance of an object.
IIS logs :
Note : I replaced sensitive information with “xxxxxxxxxxxx”
[11:04:47 INF] Request starting HTTP/1.1 POST https://xxxxxxxxxxxxxxxxxx/api/v1/schedule application/json;charset=UTF-8 267
[11:04:47 VRB] All hosts are allowed.
[11:04:47 INF] Evaluting claims for xxxxxxxxxxxxxxxxxx, Cache: True
[11:04:47 VRB] This request accepts compression.
[11:04:47 DBG] The request has an origin header: 'https://xxxxxxxxxxxxxxxxxx'.
[11:04:47 INF] CORS policy execution failed.
[11:04:47 INF] Request origin https://xxxxxxxxxxxxxxxxxx does not have permission to access the resource.
[11:04:47 VRB] Adding HSTS header to response.
[11:04:47 VRB] Performing protect operation to key {xxxxxxx-xxxxx-xxxx-xxxx-xxxxxxxxxx} with purposes ('C:\inetpub\wwwroot\', 'SessionMiddleware').
[11:04:47 DBG] POST requests are not supported
[11:04:47 DBG] Request matched endpoint 'UniversalAutomation.ScheduleController.Post (Universal.Server)'
[11:04:47 INF] Executing endpoint 'UniversalAutomation.ScheduleController.Post (Universal.Server)'
[11:04:47 INF] Route matched with {action = "Post", controller = "Schedule"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] Post(PowerShellUniversal.Schedule) on controller UniversalAutomation.ScheduleController (Universal.Server).
[11:04:47 DBG] Execution plan of authorization filters (in the following order): ["None"]
[11:04:47 DBG] Execution plan of resource filters (in the following order): ["Microsoft.AspNetCore.Mvc.ViewFeatures.Filters.SaveTempDataFilter"]
[11:04:47 DBG] Execution plan of action filters (in the following order): ["Microsoft.AspNetCore.Mvc.Filters.ControllerActionFilter (Order: -2147483648)", "Microsoft.AspNetCore.Mvc.ModelBinding.UnsupportedContentTypeFilter (Order: -3000)"]
[11:04:47 DBG] Execution plan of exception filters (in the following order): ["None"]
[11:04:47 DBG] Execution plan of result filters (in the following order): ["Microsoft.AspNetCore.Mvc.ViewFeatures.Filters.SaveTempDataFilter"]
[11:04:47 VRB] Resource Filter: Before executing OnResourceExecuting on filter Microsoft.AspNetCore.Mvc.ViewFeatures.Filters.SaveTempDataFilter.
[11:04:47 VRB] Resource Filter: After executing OnResourceExecuting on filter Microsoft.AspNetCore.Mvc.ViewFeatures.Filters.SaveTempDataFilter.
[11:04:47 DBG] Executing controller factory for controller UniversalAutomation.ScheduleController (Universal.Server)
[11:04:47 DBG] Executed controller factory for controller UniversalAutomation.ScheduleController (Universal.Server)
[11:04:47 DBG] Attempting to bind parameter 'schedule' of type 'PowerShellUniversal.Schedule' ...
[11:04:47 DBG] Done attempting to bind parameter 'schedule' of type 'PowerShellUniversal.Schedule'.
[11:04:47 DBG] Attempting to validate the bound parameter 'schedule' of type 'PowerShellUniversal.Schedule' ...
[11:04:47 DBG] Done attempting to validate the bound parameter 'schedule' of type 'PowerShellUniversal.Schedule'.
[11:04:47 VRB] Action Filter: Before executing OnActionExecutionAsync on filter Microsoft.AspNetCore.Mvc.Filters.ControllerActionFilter.
[11:04:47 VRB] Action Filter: Before executing OnActionExecuting on filter Microsoft.AspNetCore.Mvc.ModelBinding.UnsupportedContentTypeFilter.
[11:04:47 VRB] Action Filter: After executing OnActionExecuting on filter Microsoft.AspNetCore.Mvc.ModelBinding.UnsupportedContentTypeFilter.
[11:04:47 INF] Executing action method UniversalAutomation.ScheduleController.Post (Universal.Server) - Validation state: Valid
[11:04:47 VRB] Executing action method UniversalAutomation.ScheduleController.Post (Universal.Server) with arguments (["test"])
[11:04:47 VRB] Action Filter: Before executing OnActionExecuted on filter Microsoft.AspNetCore.Mvc.ModelBinding.UnsupportedContentTypeFilter.
[11:04:47 VRB] Action Filter: After executing OnActionExecuted on filter Microsoft.AspNetCore.Mvc.ModelBinding.UnsupportedContentTypeFilter.
[11:04:47 VRB] Action Filter: After executing OnActionExecutionAsync on filter Microsoft.AspNetCore.Mvc.Filters.ControllerActionFilter.
[11:04:47 VRB] Resource Filter: Before executing OnResourceExecuted on filter Microsoft.AspNetCore.Mvc.ViewFeatures.Filters.SaveTempDataFilter.
[11:04:47 VRB] Resource Filter: After executing OnResourceExecuted on filter Microsoft.AspNetCore.Mvc.ViewFeatures.Filters.SaveTempDataFilter.
[11:04:47 INF] Executed action UniversalAutomation.ScheduleController.Post (Universal.Server) in 3.9066ms
[11:04:47 INF] Executed endpoint 'UniversalAutomation.ScheduleController.Post (Universal.Server)'
[11:04:47 ERR] An unhandled exception has occurred while executing the request.
System.NullReferenceException: Object reference not set to an instance of an object.
   at UniversalAutomation.PowerShellSerializer`1.Serialize(IEnumerable`1 items) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Services\PowerShellSerializer.cs:line 391
   at UniversalAutomation.Services.ConfigurationScript`1.WriteAsync(T item, Identity identity) in C:\actions-runner\_work\universal\universal\src\PowerShellUniversal\ConfigurationScript.cs:line 135
   at UniversalAutomation.Services.SchedulesConfigurationScript.WriteAsync(Schedule item, Identity identity) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Services\Configuration\Schedules.cs:line 61
   at UniversalAutomation.Services.UniversalConfigurationService.WriteAsync(Object item, Identity identity) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Services\UniversalConfigurationService.cs:line 272
   at UniversalAutomation.Services.UniversalConfigurationService.WriteAndSyncAsync[T](T item, Identity identity) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Services\UniversalConfigurationService.cs:line 249
   at UniversalAutomation.ScheduleController.Post(Schedule schedule) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Controllers\ScheduleController.cs:line 111
   at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.TaskOfIActionResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Logged|12_1(ControllerActionInvoker invoker)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeNextActionFilterAsync>g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
--- End of stack trace from previous location ---
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextResourceFilter>g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Logged|17_1(ResourceInvoker invoker)
   at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
   at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
   at PowerShellUniversal.PSUMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Middleware\PowerShellMiddleware.cs:line 44
   at Microsoft.AspNetCore.Builder.UseMiddlewareExtensions.<>c__DisplayClass6_1.<<UseMiddlewareInterface>b__1>d.MoveNext()
   at PowerShellUniversal.FeatureMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Middleware\FeatureMiddleware.cs:line 43
   at PowerShellUniversal.DisallowedModeMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Middleware\ModeMiddleware.cs:line 47
   at PowerShellUniversal.CspMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Middleware\CspMiddleware.cs:line 21
   at Universal.Server.Middleware.RoutingMiddleware.Invoke(HttpContext httpContext, IPolicyEvaluator policyEvaluator) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Middleware\RoutingMiddleware.cs:line 202
   at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext)
   at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider)
   at Universal.Server.Middleware.SwaggerAuthenticationMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Middleware\SwaggerAuthMiddleware.cs:line 37
   at AspNetCoreRateLimit.RateLimitMiddleware`1.Invoke(HttpContext context) in C:\actions-runner\_work\universal\universal\src\AspNetCoreRateLimit\Middleware\RateLimitMiddleware.cs:line 110
   at Microsoft.AspNetCore.Session.SessionMiddleware.Invoke(HttpContext context)
   at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.<Invoke>g__Awaited|8_0(ExceptionHandlerMiddlewareImpl middleware, HttpContext context, Task task)
[11:04:47 DBG] No response compression available for HTTPS requests. See ResponseCompressionOptions.EnableForHttps.
[11:04:47 INF] Request finished HTTP/1.1 POST https://xxxxxxxxxxxxxxxxxx/api/v1/schedule application/json;charset=UTF-8 267 - 500 - text/plain 11.9579ms
All Comments (2)
(anonymous user)
For those who encounter the same problem, it is possible to get around this bug by directly creating the schedule in schedules.ps1
PSU interface :
a50c29cbed4e8195823fbd633e00c2dee092b189
Adding line like this :
New-PSUSchedule -Cron "0 8 * * *" -Script "test.ps1" -TimeZone "Europe/Paris" -tests @('firststring', 'secondstring', 'thridstring') -Name "test"
I’ve actually seen a few of these errors in the latest versions, I’m currently on 4.0.10 and I’ve had the same error when trying to change settings (happened on a couple of different occasions), ended up just doing it in the back end settings.ps1 file.
