Upgrade LiteDB to V5 didnt work as per PowerShell Universal Docs
(anonymous user)
@Adam Driscoll
Following below instruction to upgrade Litedb to V5 failed and PSU page failed to lunch
"ConnectionString": "filename=%ProgramData%\\UniversalAutomation\\database.db;upgrade=true",
"DatabaseType": "LiteDBv5",
Doing the following was Successful
Downloaded litedb.studio
Opened database.db with option upgrade from v4 selected
update appsettings.json as follows
 "ConnectionString": "filename=%ProgramData%\\UniversalAutomation\\database.db",
Now LiteDB is on V5 and so far so good.
All Comments (7)
Was there an error? I had someone do this upgrade via the instructions in the docs yesterday and it worked for them.
I just want to make sure because I was planning to roll this out in 1.6 to force this upgrade and that makes me worried it won’t work sometimes.
Adam Driscoll
(anonymous user)
Yes there was an error when launching PSU
7095bbf4d2c636dad534999a52406a9b1ced2dfa
(anonymous user)
Testing as follows:
delete database.db
launch psu to create new database.db
stop apppool
update appsettings.json as per docs instructions
start apppool
launch psu
error above
(anonymous user)
working scenario for fresh v5 version
stop apppool
delete database.db
update appsettings.json just for litedbv5 (no upgrade=true)
start apppool
launch PSU
new database.db created as V5
(anonymous user)
event viewer log below if needed
Application: Universal.Server.exe
CoreCLR Version: 4.700.19.56402
.NET Core Version: 3.1.0
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
 ---> System.ArgumentException: The path is empty. (Parameter 'path')
   at System.IO.Path.GetFullPath(String path)
   at System.IO.FileInfo..ctor(String originalPath, String fullPath, String fileName, Boolean isNormalized)
   at System.IO.FileInfo..ctor(String fileName)
   at UniversalAutomation.LiteDBv5Database.SetupTables(ILogger logger) in D:\a\universal\universal\src\UniversalAutomation.LiteDBv5\LiteDBDatabase.cs:line 74
   at UniversalAutomation.LiteDBv5Database..ctor(IServiceProvider serviceProvider) in D:\a\universal\universal\src\UniversalAutomation.LiteDBv5\LiteDBDatabase.cs:line 54
   --- End of inner exception stack trace ---
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor, Boolean wrapExceptions)
   at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture)
   at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
   at System.Activator.CreateInstance(Type type, Object[] args)
   at Universal.Server.Startup.<>c__DisplayClass6_0.<ConfigureServices>b__10(IServiceProvider s) in D:\a\universal\universal\src\Universal.Server\Startup.cs:line 331
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitFactory(FactoryCallSite factoryCallSite, RuntimeResolverContext context)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSiteMain(ServiceCallSite callSite, TArgument argument)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitCache(ServiceCallSite callSite, RuntimeResolverContext context, ServiceProviderEngineScope serviceProviderEngine, RuntimeResolverLock lockType)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitRootCache(ServiceCallSite singletonCallSite, RuntimeResolverContext context)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSite(ServiceCallSite callSite, TArgument argument)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitConstructor(ConstructorCallSite constructorCallSite, RuntimeResolverContext context)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitIEnumerable(IEnumerableCallSite enumerableCallSite, RuntimeResolverContext context)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitNoCache(ServiceCallSite callSite, TArgument argument)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.Resolve(ServiceCallSite callSite, ServiceProviderEngineScope scope)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.DynamicServiceProviderEngine.<>c__DisplayClass1_0.<RealizeService>b__0(ServiceProviderEngineScope scope)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngine.GetService(Type serviceType, ServiceProviderEngineScope serviceProviderEngineScope)
   at Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngineScope.GetService(Type serviceType)
   at Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetService[T](IServiceProvider provider)
   at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
   at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
   at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
   at Universal.Server.Program.Main(String[] args) in D:\a\universal\universal\src\Universal.Server\Program.cs:line 31
Ok. Thanks for all the info. Maybe it something to do with IIS. I’ll take a look.
Adam Driscoll
(anonymous user)
I have the same issue now after installing/ removing IIS on my server. Are there any news to this topic?
I now have to reinstall my Server in hope to not face this issue again.
