"Use active Hub/Cloud datasource' checkbox for entries of type 'Hub privileged account'
1 vote
With DVLS as a data source, it is possible to check the option to use active data source when creating 'DVLS privileged account' type entries using RDM.
When attempting to create an equivalent type entry with a Hub/Cloud datasource, the user has to either enter an email address (or preset their respective 'My Account' setting), and then manually select a Hub account for every entry, which is somewhat cumbersome.
Could a 'use active datasource' option been accommodated to simplify the user experience for Hub/Cloud usage scenarios please?
Please let me know if you would like any additional info.
Thanks
Joe
Hi @jm2,
Thank you for reaching out, we'll look into adding this.
Cheers,
Luc Fauvel
Hello Joe,
We'll have this setting available starting with version 2027.1, coming out late this year. It applies to the Cloud credential and the Cloud PAM entries.
Additionally, there's a helper when you check the box if you want to fill the information with your current workspace's information. This can help in scenarios where you're filling out the My Personal Credentials for example and you want the information to be static, but want to avoid writing it down yourself.
Let us know if you'd like any tweaks once this is available.
