Has something been done to the filter as I need to click into it twice when working in RDM and other open applications/windows to remove the <Search>? In the past all I would need to do is click into it, type, enter and the session would connect. Now I need to click into the filter twice to proceed in typing the session name and then enter.
I'm unable to reproduce it. What other application do you have opened? Is it an external process like Putty? I tried with an embedded notepad
Hi David,
Only applications I have open are MS Outlook and Track-It! for internal Help Desk tickets.
Felix.
Do you use the classic UI mode?
Hi David,
No I am using the default ribbon view in 8.9.17.0
Felix
Hi David,
Were you able to find anything else on the issue? Was the <Search> always in the filter box? Also I have noticed a double-click issue on my connections in which I would need to double-click my connections a second time in order to have then connect? Was wondering if any changes were recently done that would affect the double-click?
Felix
I haven't found anything for that yet. The only thing I could see is when the application does not have the focus. The click is not pass through and it used only to focus the main form
