Powershell Script Makro to be Executed on Remote Host with Credentials from Remote host
Hi there,
i've a simple Powershell Script that needs to be executed on the Remote Host, not locally.
But i do not get it to work, since it's never using the correct Credentials for that Session. It seems not respecting the inheritance from the Credentials on the host?
I already tried with the "Use Credentials from Session, but that does not work either".
When i have a host with hardcoded credentials, it seems working. But not when we use the "Credential override for user specific settings on the upper folder"
Anyone out there with the same issue or an idea how to solve this?
Hello Constantin,
Thank you for contacting the Devolutions Support team.
Could you tell me if this is working with the PowerShell remote session entry?
Could you also change the management tools password and use the Run as Admin?
https://docs.devolutions.net/pam/kb/how-to-articles/management-tools-elevated-privileged-account/
Patrick Ouimet
