Issue with 1Password and BitWarden integration
This version broke integrations with 1Password and BitWarden has similar issues. I have had to revert back to using KeePass integration for credentials. When trying to connect to an RDP session with 1Password configured it prompts the first time for my password for 1Password then throws this error. Also using the Open Session button seems to not work at all with this release. It seems very flaky getting RDP sessions to work the first time.
Error with 1Password configured on first launch of any RDP session -
Seeing this as well after entering the 1Password unlock password -
This message comes up then does not allow RDP to the connection. I need to change the credentials back to KeePass ones before it works.
Please address this
All Comments (33)
Could you confirm which type of data source you are using?
https://docs.devolutions.net/rdm/data-sources/data-sources-types/
You mention that you are having this issue with the first launch. Am I correct in assuming subsequent launches are working as expected?
If you go under "Help" -> "Application Logs" are there logs generated relating to this error? If so can you provide us the full logs.
Let me know,
Samuel Dery
I am using Microsoft SQL Server (Express) on my laptop for my database and datasource. If I do not change the credentials the second launch throws the same errors. After changing the credentials then it works by double-clicking but not the Open Session button - it seems that is dead.
I will check for logs to see and attach.
@Samuel Dery Here are the error logs for the problem, which started yesterday after the upgrade on Wednesday to the 2025.3 release.
Thank you for your reply,
I see, I can reproduce the behavior, I have opened a case with our development team which I will link to this topic,
We will keep you updated with any news we have regarding this,
Samuel Dery
Perfect. Glad this helped, and hopefully we can get these issues resolved in the next release. I will keep an eye on this thread.
Please also ensure the Open Sessions button is fixed too as that is not working at all either. The only way for me to launch a session is double-clicking.
It is funny I have another system that has the same beta build and the open sessions button works. But it does not have 1Password or Bitwarden integrations.
