Strange behavior with acutes in spanish
Hello!
When connecting to ARD or a Macos VNC, typing acutes produces an strange behavior when I do it with an external hardware keyboard. In example, when I want to write an "á" pressing ´ and a, the results is 'á.
Both machines are in a Spanish ISO keyboard distribution, as my iPad external keyboard.
Do I have to change anything in my settings or is it a bug?
Thanks in advance,
Ugo
All Comments (6)
Thanks for your feedback.
We’re currently investigating the issue you’re experiencing with accented characters when using an external keyboard via ARD or VNC. Both machines using a Spanish ISO layout should normally behave as expected, so this may be a bug or a configuration-related problem.
We’ll get back to you as soon as we have more information.
Johann Dufaud
After further investigation, we believe we’ve identified the issue.
We will correct it, test the fix, and include it in an upcoming release.
Johann Dufaud
Perfect!
Thank you very much!
We’ve just released version 2025.2.3.1, which includes the fix.
Maxime Brousseau
Tested and working!!
You are the best!
Ugo
Thank you for your feedback! We are glad to hear the problem has been resolved.
Maxime Brousseau
