Issue connecting to RDP in fullscreen
hello Team
After this update i cannot set the RDP conncetion from linux to windows machine in full screen,
could you help please,
before this update Version 2025.2.1.3 (July 22, 2025), the full screen work perfectly.
best regards.
Thank you for reaching out to Devolutions Support.
Could you please send us a screenshot of the entry properties?
This will help us better understand the issue.
Carl Marien
Hi, I'm facing the same issue.
The display related settings are like this:
Right-click the entry and "open full screen" does not work too:
Right click the connected session tab and "Settings..." -> "Full screen" also doesn't work.
I'm on 2025.2.1.5 on Fedora 42, Gnome 48.4, Wayland
Do you need more information ?
BR
Markus
Thank you for the information. Are you receiving any error messages or something similar when trying to connect?
When RDM on Linux opens an entry externally, it typically uses `freerdp2-x11`. Could you please check if it is currently installed on your system?
If not, try installing it using the following command and see if the connection works:
sudo apt install freerdp2-x11
Carl Marien
