Version 5.7.0.12 Beta - Problems focusing sessions
I don't know if this is a bug or a technical limitation, but when switching between sessions clicking on the session tab, the focus does not go to the window. It works fine for RDP, but does not work for SSH or VNC.
I use all sessions in tabbed mode, so if I click on the tab of a RDP session with notepad open, I can start typing as soon as I click on the tab. But with SSH/putty, if I click on the putty session tab, the focus does not go the putty window, and I cannot type. I need to click on the window to really get focus. Right-clicking the session on the left pane and choosing Focus Session also gives the same behaviour. Exactly the same occurs with VNC sessions.
Is there any way to solve this problem?
BTW, I liked this program a lot, it's much more stable than some other managers that I tried!
Thanks,
Claudio Neves
All Comments (5)
Hi Claudio,
Thank you for your feedback. This might be a limitation especially with Putty but it was not the expected behavior. I will take a look and see if I can fix it.
Devolutions inc.
How about this problem???
Is it possible to fix?
thank you
It's on my todo list, I will try to fix it soon.
hello
maybe impossible to fix this problem?
all my sessions is shh/putty and a little uncomfortable then focus does not go the putty window.
Thanks... I like this program.
I will see what i can do, not sure.
