CNAME to Devolution Hub Url
is there a way to refer to the Devolution Hub URL with a CNAME to use your own domain, or is this only possible with the Devolution Server?
Thank you
Br
Markus
Recommended Answer
You can forget my last reply.
We do not make any URL changes on our side, as we always maintain the same template.
You cannot configure a CNAME for the URL using your own DNS server.
This will cause some TLS errors since the certificate is only valid for devolutions.app
Please let me know if you need further information.
Jacob Lafrenière
All Comments (1)
Jacob Lafrenière
