allow group of users to export vault
How can I configure Vault permissions to allow a group of users to use the export option on specific vault?
Recommended Answer
Thank you for reaching out!
My name is William and I'm here to assist you in any way I can.
It is possible by setting the group as a Vault Owner on the specific vaults under Administration > Vaults.
Note that a Vault Owner is considered to be an administrator of the vault and permissions won't apply to that user where he is configured as a Vault Owner.
You can also configure the Export permission under Administration > System permissions > Entries, but this will allow the export on every vaults the user has access to.
Feel free to reach out if you have any questions or need further clarification.
Hi @williamThank you for your response. Your answer resolved my question.
Thank you for your feedback. I'm glad to know I was able to answer your question.
I will set this thread as resolved. Feel free to reach out if you have any questions or need further clarification.
Elevate your learning - Join the Devolutions Academy!
