Good morning.
Just upgraded to v2025.1.11.0. First off, want to say THANK YOU for finally pushing the update to show User Vault Expiring entries. This is EXTREMELY helpful.
However, I have found an issue with ONE item and that's the "Checkouts" List.
As you can see, I have everything (except one Never) set to "If not empty":
The list shows 0 checkouts so therefore, it shouldn't be displayed.
Otherwise, haven't found any issues with the Dashboard for either System or User vault. Showing my user vault settings for reference here:
Only suggestion I can think of, is maybe (if feasible) is to have a growing window? You can see my Expiring entries has a scroll bar. It would be nice to see them all without having to scroll. Maybe an option in settings to show how many entries appear in all the windows?
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.2.16.0 64-Bit - Free
I spoke too soon.
The same issue with Dashboard not saving that I reported a few versions back is happening again.
Every time RDM is exited, it reverts the Dashboard settings back to the defaults you folks push out.
Please compare the two Dashboard Settings screenshots listed in this post. The 1st one is what I selected. The one directly above this line is after closing and re-launching the program.
--- Chuck
Hello Chuck,
What type of data source are you using? I'm assuming this is your SQL Server is that correct?
I've not been able to reproduce the behavior so far with the Beta version. Could you install a portable instance and let me know if you encounter the same issue?
https://cdn.devolutions.net/download/Devolutions.RemoteDesktopManager.Bin.2025.1.11.0.zip?_gl=1*7tm9d8*_ga*NTI1MjMyNzQwLjE3MzE5Njg0MTM.*_ga_P11646PR82*MTczODgwMjU5NS4yMDIuMS4xNzM4ODAyOTc2LjYwLjAuMA..
https://docs.devolutions.net/rdm/kb/how-to-articles/portable-rdm-installation/
Samuel Dery
Hello Chuck,
My apologies, sir. I should have put I checked both versions as I always do before posting a found issue.
I get the exact same results with the portable version, I just didn't display the results for that one as well, so here you go.
I even attached the taskbar so you can see the time and notice the change in exiting / relaunching RDM.
First startup after downloading:
This is what I changed the settings to, which is my preferences.
After exiting RDM, waiting a couple minutes and relaunching, it reverts back to what you folks push out:
I have confirmed this same behavior on two different instances. My main instance which is on my laptop, and my VM instance which is utilized for when I need to connect to different VPN's.
Both machines work perfectly fine on the latest v2024 that I had installed. When I make a change to my Customize list, it saves it and loads as expected on each launch. The Beta version (both installed and Portable) goes back to this issue. It is the exact same behavior that I reported as a bug the last time you folks made a change to the way the Dashboards were viewed. Something was found and fixed in the next release.
Thanks.
--- Chuck
Hello Chuck,
Thank you for your reply,
Indeed, I remember being able to reproduce this issue at the time you reported it,
Would you be able to provide me with a recording of the behavior? There might be something we are doing differently.
I will send you a link in a private message so that you can provide me the recording.
Samuel Dery
