API call with Devolutions Cloud failed. (Forbidden - Two factor required)
Resolved Implemented
Hi Erica,
I'm getting this error when trying to connect with the PowerShell API:
Connect-HubAccount: The api call with Hub failed. Forbidden - Two factor required
How can we exclude an API user from otherwise enforced MFA?
Thank you!
Yannis
All Comments (4)
Hello Yannis,
Thank you for reporting this issue.
It's a known issue, and a fix is ongoing. We should release a new Hub version early next week. We will keep you posted once a new version is available.
For your information, I have moved your post to the Devolutions Hub - Bug Report forum's section.
Érica Poirier
Hello Yannis,
The fix has been released with the server version 2024.1.7.
Could you try again and see if it works for you now?
Have a good day!
Maxime Morin
Thank you Érica and Maxime, ça va bien maintenant.
Hi Yannis,
Thank you for the update! We're delighted to hear that the recent fix is now functioning well for you. Please do not hesitate to reach out if you encounter any further issues or have additional questions.
Merci pour voter patience!
Érica Poirier
