Android 14 & / Pixel 8 Pro and Italian Language bug...
Hi I notice 3 bug on latest 2024.1.1.3 and Android 14 arm64 on Pixel 8 Pro and Italian Language
1) app crash/close if I try to select tools/ssh key generator
2) if I delete a Items and try to import a rdm backup app crash /close
3) if try to go on settings whit 3 dot menu / impostazioni app crash / close
All Comments (13)
Have you tried clearing the application cache in the Android Storage & Cache section to see if the issue persists?
Frederick Simard
Yes of course... The bug is present also on Fresh Installation whitout any data source
I try to post logcat as soon possible..
Would you mind performing a few tests for us?
Could you please open the Ping Tool and check if it crashes?
Could you navigate to the About section (via the 3-dot menu) and let us know if it crashes there as well?
Afterward, could you add a new entry of type RDP and see if the editing page opens correctly?
And finally, could you add another entry of type PowerShell and check if the editing page opens correctly?
Best Regards,
Frederick Simard
1) Yes also on Ping Tool app crash /close
2) About work fine no problems
3) add new entry rdp and after edit connection work fine...
4) when try to add new entry power shell app crash / close
Best Regards
Thank you for your response !
We may have a clue about what the issue might be. Would you mind testing out a custom build to see if it fixes the issue?
Best Regards,
Frederick Simard
When you want...
any info for download tested version?
We will send you shortly a direct message for you to test.
Frederick Simard
I have reply to PM..
The fix is currently being rolled out. If not available to you yet, it should be in the next couple of days !
Frederick Simard
Ok tks...
any news on new release? Tks
The new release should now be available to all users.
Best Regards,
Nicolas Dufour
yes correct... preliminary test : all ok.. regards
