Setting up synchronizers for Devolutions Cloud on a separate machine
I'm trying to follow this tutorial: https://docs.devolutions.net/kb/remote-desktop-manager/how-to-articles/running-rdm-synchronizer-centralized-server/
it appears the portable version of devo is read only with the latest updates. Will this version be updated any time soon? Do i have to install the full version?
All Comments (1)
Hello Ross,
You will need to create a new portable installation or replace the files in your portable installation folder, the .zip file of the latest version is always available with the releases of new versions and can be found directly on our website here:
https://devolutions.net/remote-desktop-manager/home/downloadenterprise/
Here is a direct download link to the latest version .zip file for your Portable installation:
https://devolutions.net/remote-desktop-manager/home/thankyou/rdmbin/
Let me know if this helps or if you have further questions regarding this,
Samuel Dery
Ends in 12 days
