iOS - Autofill verification codes using Devolutions Password Manager
Implemented
In iOS Settings > Passwords > Password Options > AutoFill [enabled]
AutoFill for Passwords works fine in Workspace once you added it as an Autofill option, but there is no option for verification codes.
This option is available in many other password managers. I can see Bitwarden, Microsoft Authenticator and Duo in my options but not Workspace.
I'm hoping this is trivial to implement and will be available soon.
All Comments (4)
Hi, do you store your verification codes in the Authenticator Space in Workspace or in you Devolutions Hub Personal/Business Space?
Thank you
Sébastien Aubin
Product manager - Password Management
Thanks for the fast response Sébastien,
We store the OTPs inside Devolutions Server (on-premise) Space, not the Authenticator Space.
Cheers
Hugh
Hi, thank you for the clarification.
Currently, the feature you mentioned is not available on Devolutions Server. However, I will add your request to our backlog. We should be able to implement this feature in an upcoming minor version, as it is already implemented in the Authenticator Space.
Thank you,
Sébastien Aubin
Hi, this feature is available in the latest version of Workspace. When there’s an OTP linked or custom in the website entry, the code will be added to the clipboard when autofilling the username/password. Don’t forget that the codes have a 30 seconds lifetime and if you do the process at, let’s say 11:59:55, you’ll only have 5 seconds to use the code.
Sébastien Aubin
Ends in 7 days
