Viewing username and host columns has a huge impact on workflow. It's further amplified when searching a known value, but having to click each individual entry to determine what field out of the selected ones for search is even being matched.
Hi lfudala,
I'll open a ticket for this, but, unfortunately, we have no immediate plans to implement this feature. In the meantime, you could enable some fields in "Field Options" in the navigation pane search settings (pressing the button highlighted in the attached picture) or use the advanced search. I know those might not be as convenient as adding columns and seeing all your entries' values at once, but it'll at least allow you to search for entries with specific fields until we implement it.
Kind regards.
Nicolas Parr
Hi Nicolas,
I do use the extra fields to search already.
Yes, the value in seeing all the results in columnar view has a few benefits, especially when working with a group of hosts matching some query or a group of accounts that use a purchasing email.
Cheers
