I usually add to script files directive to load required modules. For RDM module:
#Requires -Modules Devolutions.PowerShell
But from some time, it does not work any more. The script states that module is not loaded. Probably because the abovementioned module loads module with another name instead:
PS ❯ get-module Devolutions.PowerShell* -list
Directory: C:\Program Files\PowerShell\Modules
ModuleType Version PreRelease Name PSEdition ExportedCommands
Binary 2023.1.0.8 Devolutions.PowerShell Core {Add-RDMRoleRepositoryAccess, Add-RDMRoleToUser, Add-RDMSession…
Binary 2023.1.0.6 Devolutions.PowerShell Core {Add-RDMRoleRepositoryAccess, Add-RDMRoleToUser, Add-RDMSession…
ModuleType Version PreRelease Name ExportedCommands
Binary 2023.2.0.1 Devolutions.PowerShell.Extension {Add-HubGroupUser, Add-RDMPrivateSessionAttachment, Add-RDMRoleRepository…
This second (loaded to memory) module is not visible for PowerShell, so I can't add #Requires directive into script for this module.
Is this change documented anywhere? Since which version this change occurred? Can it be changed back? Or how I am supposed to ensure that correct module is loaded before script starts work?
Meelis
Hello Meelis,
It's probably because of the multiple installed versions you have on you machine.
Did you get module version 2023.2.0.1 version to test it? It hasn't been officially released yet.
And for version 2023.1.0.6, you can remove it using the Uninstall-Module cmdlet so it won't affect your script anymore.
Does it work on a machine where only the latest official version 2023.1.0.8 is installed?
Érica Poirier
I removed module version 2023.1.0.6 and after that the problem resolved. The correct module is loaded and #Requires directive works again.
PowerShell usually loads always the latest version of installed modules. Does the Devolutions.PowerShell module changes the default loading sequence?
I see, that abovementioned module has nested module (named Devolutions.PowerShell.Extension) defined that actually loads the same .dll file. Is it possible that this confused PowerShell to think that the .extension module is right one to load?
Thank you for your feedback and glad that removing version 2023.1.0.6 solved the issue.
I have asked our engineering team about your question regarding the nested module and we will keep you posted.
Thank you for your patience.
Érica Poirier
