Module Devolutions.PowerShell problems
How the new module is supposed to be used with RDM and SQL databases?
The only command that works without long error message (in wrong stream), is Get-RdmDataSource. The Get-RDMCurrentDataSource give me current data source, but also long "error" message:
The type initializer for 'NetSecurityNative' threw an exception.
at Interop.NetSecurityNative.ImportPrincipalName(Status& minorStatus, String inputName, Int32 inputNameByteCount, SafeGssNameHandle& outputName)
at Microsoft.Win32.SafeHandles.SafeGssNameHandle.CreatePrincipal(String name)
at System.Net.Security.SafeDeleteNegoContext..ctor(SafeFreeNegoCredentials credential, String targetName)
at System.Net.Security.NegotiateStreamPal.EstablishSecurityContext(SafeFreeNegoCredentials credential, SafeDeleteContext& context, String targetName, ContextFlagsPal inFlags, SecurityBuffer inputBuffer, SecurityBuffer outputBuffer, ContextFlagsPal& outFlags)
at System.Net.Security.NegotiateStreamPal.InitializeSecurityContext(SafeFreeCredentials credentialsHandle, SafeDeleteContext& securityContext, String[] spns, ContextFlagsPal requestedContextFlags, SecurityBuffer[] inSecurityBufferArray, SecurityBuffer outSecurityBuffer, ContextFlagsPal& contextFlags)
at Microsoft.Data.SqlClient.SNI.SNIProxy.GenSspiClientContext(SspiClientContextStatus sspiClientContextStatus, Byte[] receivedBuff, Byte[]& sendBuff, Byte[][] serverName)
at Microsoft.Data.SqlClient.SNI.TdsParserStateObjectManaged.GenerateSspiClientContext(Byte[] receivedBuff, UInt32 receivedLength, Byte[]& sendBuff, UInt32& sendLength, Byte[][] _sniSpnBuffer)
at Microsoft.Data.SqlClient.TdsParser.SNISSPIData(Byte[] receivedBuff, UInt32 receivedLength, Byte[]& sendBuff, UInt32& sendLength)
The similar text will occur, when I try to use Set-RDMCurrentDataSource cmdlet.
The Get-RDMLicense and Get-RDMUser will give similar text + warning:
WARNING: Your connection is not ready
The local XML data source works without problems.
The PowerShell version is 7.3.4
Devolutions.PowerShell module version is 2023.1.0.4
The RDM version is 2023.1.22.0
On the same machine, the RemoteDesktopManager module (version 2022.3.1.7) works under PowerShell 5.1 without problems
Meelis
All Comments (2)
Hi Meelis,
This is a known issue of version 2023.1.0.4. Upgrading to 2023.1.0.5 or .6 should solve the problem.
Regards.
Jonathan Lafontaine
Thanks, module upgrade helped.
