how to use TOTP with RDM for forums.devolutions.net ?
Resolved
My entry for forum.devolutions.net:
On my account, I have OTP set up, using Authy.
I want RDM to handle the OTP part, so I can remove the key from Authy.
I'm logged in on this forum
  • click on my avatar at the top right corner
  • click 'Manage Account'
  • click 'Sign-In & Security'
  • click 'Manage' next to 'Two-Step Verification'
  • I already have Authy installed, I don't need/want the 'Devolutions Workspace' app
  • I copy the key (next to the barcode) into the OTP 'Key' field in RDM (Source: 'Custom')
  • the 'Wait for application synchronization.' times out
How can I use TOTP from within RDM on this very forum without installing yet another app?
All Comments (6)
When configuring your 2FA in your Devolutions Account, could you use "Authenticator App" instead? :
From there, copy the key in your OTP entry, which will generate a code that you will be able to set
This way, you will not need any (mobile) application to setup your 2FA.
Best Regards,
Etienne Lord
