Password Hub Importer, issue with CSV
Hello
I'm trying to use the importer with some CSV files, but after a first correct import job, is no more possible to import other CSV files.
After the preview, the tool cannot detect the separator so the files are considered empty.
Attached some screenshots that are showing how the character is not correctly set (the accounts are fakes).
The tool version is 2022.3.32.0 on Win 11prod
Thank you
Screenshot 3Screenshot 2Screenshot 1
Hello Samuele,
Our engineering team is currently looking at the issue, we will report back shortly.
Richard Boisvert
Hello Samuele,
The issue will require further analysis after all, we will keep you posted.
In the meantime, you can use RDM to import the CSV file in your Password Hub Business, you can request a trial license with this link: https://devolutions.net/remote-desktop-manager/trial
Richard Boisvert
I have tried many times and even used the data set shown in your screenshot but could not reproduce this issue.
Do you still experience this issue on the latest version of the Hub Importer?
Best Regards,
Michaël Beaudin
