Using "Linked (Vault)" passwords in PM
Resolved
Good morning, all.
Is there a way possible to link the Vaulted Credentials I have in KeePass to the PHP?
I currently have all my Vaulted credentials in RDM linked to KeePass.
Thank you!
forum image
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.3.2.0 64-Bit - Free
All Comments (4)
Thank you for contacting the Devolutions Support Desk !
Are you using the Password HUB Personal as a data source in RDM ?
What other types of data sources do you have in RDM, if there are any?
Best Regards,
No, sir.
All my credentials are stored in KeePass, and just using the standard "Local Data Source" that RDM comes with.
--- Chuck
From what I understand from your messages, you already have your KeePass Credentials in your Local Data Source (SQLite) data source in RDM?
You can use Hub Personal directly in RDM (As explained here: https://kb.devolutions.net/kb_moving_phub_personal.html), this way the KeePass credentials that you created/imported in your "Local Data Source" can be exported from this data source to your Hub Personal data source. (How to import.export: https://kb.devolutions.net/how-to-import-and-export-entri.html)
Once your credentials will be imported in your Hub Personal data source, you will be able to link them in other entries that also are in your Hub Personal data source.
Olivier Désalliers
That is exactly what I was looking for. I read the 1st link and that worked perfectly.
Where my error was earlier, I was trying to do a Copy / Paste from and to, and that wasn't working.
Much appreciated, and Merry Christmas!
--- Chuck
