Web interface dark mode and documentation
Implemented
Hi
When running DVLS Webinterface in Dark mode, text under Documentation is also black
Regards Lars
Remote Desktop Manager connected with Devolutions Server running newest versions.
------------------------Signature------------------------
Sorry if any of above sounds harsh or provoking, it is NOT meant as such, but I have Asperger's and don't always know.
My intentions is always to be friendly.
All Comments (4)
Hello Lars,
With the latest DVLS 2022.3.4 version, I cannot reproduce this issue.
What browser are you using?
Érica Poirier
Hi
Yes also using the 3.4.
I use Edge (Chromium) always updated.
I believe some of my colleagues use other and they have the same.
Windows i set to dark mode, and dvls is set to default (light/dark).
/Regards Lars
Hello Lars,
Thank you for your feedback.
On my end, the DVLS was set to Dark mode. That's why I wasn't able to reproduce it.
With the DVLS set to default and having both Edge and Windows in dark mode, I can reproduce your issue.
A ticket has been submitted to our engineering team. Once a fix will be available, we will update this post.
Thank you for your patience.
Érica Poirier
zellaham
Disabled
Hello M.Lars,
We have fixed the issue and it should be available on the next DVLS release.
Thank you for reporting it !
Zacharia Ellaham
