SSH Shell issues - 2022.3.8.0 64-bit (Beta)
Multiple issues with SSH Shell sessions make the new RDM hardly usable for us:
  1. using a German keyboard, the whole "Alt+Gr" generated characters ("{", "[", "]", "}", "\", "~", "@", "|") are unavailable.
  2. the session tab becomes unresponsive to key presses (or generates only upper case characters) after switching between GUI windows. If you close the SSH Shell tab and reconnect (the shell is running in GNU screen) the tab becomes responsive again - for a short time.
  3. the font display is severely blurry. See
versus RDM 2022.2.26.0 below
The icons are actually displayed correctly (the font is DejaVuSansMono NF) but the text is difficult to read on the upper screen shot. The operating system is Windows 10.
All Comments (2)
Thanks for the feedback. I will fix those problems as soon as possible. I can already reproduce the alt+gr bug.
Denis Vincent
I made a fix for the alt+gr and tab bugs. I also think I fixed the blur bug, but since it is not something we experience here, I can't tell for sure. Those fixes should be available in the next release.
Denis Vincent
