offline mode graceful on/off
Currently, Whenever you need to re-auth all of RDM becomes unusable so the tranistion from offline to online mode requires a re-auth. Example it seems RDM after some period of time the Devolutions Server requires a re-auth. If i am in the middle of a ssh session and try to use system-wide Find Quickly or hotkey for User vault entry I am blocked. Which often opens another browser window to re-auth, which moves you between windows. Causes a workflow speed bump and random browser windows open i have to remember to close.
In the case where offline mode caching is an option and using some sort of Local Application security these should apply.
I have few thoughts.
1- User Vault it seems like it should always be available. I hit a chicken and egg problem. I need my password from my User Vault to auth to the Devolutions Server, but I am blocked from my entries even though I have auth'd to get into RDM to access my user vault.
2- Offline mode doesnt allow you to add/modify entries that would later be pushed when online mode becomes available. It is not unheard of I am in the field need to create a temp password I want to save, but I don't have network access on my laptop. If I am modifying an entry and there is conflict. RDM could create a conflict folder and offer maybe "merge entry" option. Also if access to the devolutions servers that requires a VPN not having a mechanism to have some interaction puts me in a bind. I am often in the field in offline mode situations.
3-using an embedded webview or view controller and move the auth to the background to not block all interaction with RDM and entries if you have authenticated with Local Application security.
All Comments (22)
Hi georgesnow,
For the general needs to reconnect occasionally, this might actually just be a bug, I'll have to get in touch with the DVLS team to be sure.
Unfortunately, I do not think this would be possible. In the end, your User Vault, like any of the Shared Vaults, is still stored inside the database of the Devolutions Server, if the authentication as expired, your User Vault is as unavailable as any of the Shared one.
This should be possible, do you have the "Offline mode" of your server System Settings set to Read/Write? See:
We've actually moved away from using embedded webviews for Oauth authentication, I don't know if we intend to add back support for it. As for doing it in the background, I believe this is what is supposed to be done currently, hence why I believe you might be hitting a bug.
Xavier Fortin
Hmm, i can't to locate "System Settings" that you show in your screenshot. The closest thing I have is under data sources->Advanced tab. And I have caching mode, Prompt for offline mode, auto go offline, Connection timeout, auto refresh and manage cache.
how do you navigate to that view?
