Anydesk connection for Linux enviroment
Implemented
Hello is there a chance that RDM for linux have Anydesk connection in futures updates?
All Comments (4)
AnyDesk is supported on Linux which is a good start.
I'll open a ticket to evaluate and work (if possible) on an AnyDesk integration for RDM Linux.
Regards.
Jonathan Lafontaine
Hello Jonathan,
that would be really desirable!
Stefan
Good news, we have implemented AnyDesk support in RDM Linux.
You will need AnyDesk installed on your workstation and the session will start externally.
But it will work.
It will be available in our next minor release (2022.2.1.x)
Jonathan Lafontaine
Hi Jonathan this are really good news. Thanks.
Closed
