External RDP session does not open in selected monitor
Implemented
Define an RDP session with 'Display': 'External' + 'Primary monitor'
No matter what I choose as monitor, the session always opens on the current monitor.
$ xrandr
Screen 0: minimum 8 x 8, current 3840 x 1200, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 518mm x 324mm
   1920x1200     59.95*+
   1920x1080     60.00
   1680x1050     59.95
   1600x1200     60.00
   1280x1024     60.02
   1280x960      60.00
   1024x768      60.00
   800x600       60.32
   640x480       59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected 1920x1080+1920+120 (normal left inverted right x axis y axis) 344mm x 194mm
   1920x1080     60.02*+  48.03
DP-5 disconnected (normal left inverted right x axis y axis)
DP-6 disconnected (normal left inverted right x axis y axis)
$ xfreerdp /monitor-list
      * [0] 1920x1200	+0+0
        [1] 1920x1080	+1920+120
Selecting 'Prompt on connection' does not prompt for anything.
All Comments (6)
Hi David,
I can reproduce the issue internally.
We will look into it.
Gabriel Dubois
Hello David,
The issue has been fixed internally.
All changes will be effective in the next update (2022.1)
Gabriel Dubois
Can confirm that choosing a monitor puts the session on the correct monitor.
My final remark "Selecting 'Prompt on connection' does not prompt for anything." still does not prompt for a monitor, though.
We'll recheck that part.
Thanks for letting us know.
Jonathan Lafontaine
Hello David,
The 'Prompt on connection' issue has been fixed internally.
It will be effective in the next update (2022.1.1)
Gabriel Dubois
Version 2022.2.0.3 seems to behave as advertised.
Keep up the good work!
