Yubikey USB not work - datasource 2fa
When connecting to datasource (DPS) with Yubikey 2fa work fine by NFC but when connect Yubikey by USB not work.
In other places application Yubikey works as keyboard fine
Thank you for your feedback. We will investigate.
Can you specify your phone model and manufacturer?
Best Regards,
Nicolas Dufour
I was try on Samsung Galaxy S10 and Galaxy Tab S7 FE 5G
tprudhomme
Disabled
Following your bug report, we fixed the issue in the current development version. It will be released in the next update, either in November or December.
Best Regards,
Tommy Prud'homme
