"Is Virtual machine" missing from column chooser in RDM 2021.2.11.0 (beta)
The field Is virtual machine is missing from the column chooser, which is a bit of a pain.
Could you guys please add this again?
Kind regards,
Raymond
We will open a ticket to add this column and update this thread once we've made the change. Thanks for the request!
Thanks Hubert!
Hello!
We've been looking into your issue, and the *Is Virtual Machine* selection still seems available to us, both in the *Dashboard* as well as the main *Tree view*. It is located alphabetically between the *IP Address* and the *Last Inventory Load*. If the selection is not available to you, there might be something we're missing, and we'd appreciate some context (such as the area where you are attempting to use the feature).
Here's a screenshot for clarity.
Jafran Majeau
Hi Jafran,
When I right click on the columns and choose Column chooser, there it's not in the list anymore:
Hello!
I would like to ask you to try certain things to see if it would fix the issue.
Could you first try using the "Best Fit (All Columns)" to see if the virtual machine is still selected but simply "hidden outside of view".
If that doesn't work, attempting to reset your layout might bring back the possibility to select it.
Let me know if either of these fixed the issue for you.
Jafran Majeau
Hi Jafran,
Best fit (all columns) fixed this, thank you!!
