Allow multiple connection on one ssh shell entry
Implemented
I use this software on my iPad, it's an excellent software.
To use multiple shell on one server, I need to use tmux or duplicate ssh shell entry,
I think it's not very convenient that a ssh shell entry can open only one connection.
Do you have plan to add this feature?
We have an option under RDM Windows to allow this specifically. In RDM Windows, if you go in File -> Options -> Application -> Allow multiple connections and turn this option on, it will allow you to perform multiple sessions on the same host.
However, I don't see this option under RDM iOS. I opened a ticket to our engineering department regarding this.
Thanks a lot.
I just wanted to provide a quick update on that matter.
Our Engineering Department has just informed us that the feature has been implemented and that it should be released in the coming versions of RDM. While we are not sure that it will be in the next version, it will surely be in the one that follows.
James Lafleur
