Templates issue
Ich habe ein Template in folgender Struktur angelegt:
Ordner FOO
Host FOO
Session FOO SSH
Ebenfalls wurde im Template hinterlegt: Automatischer Start einer Unterverbindung FOO SSH
Nun erstelle ich ein neuen Eintrag FOO2
Ordner FOO2
Host FOO2
Session FOO2 SSH
Wenn ich jetzt FOO2 SSH starte wird mir FOO SSH und FOO2 SSH als aktive Session angezeigt. Man kann dann nur über umwege FOO2 SSH öffnen, da er ja denkt es sei schon offen
Das Problem kommt anscheinend nicht, wenn ich im Template "Automatischer Start einer Unterverbindung FOO SSH" entferne
All Comments (6)
Sorry to intervene in English, I will try to recreate the behavior on my side and comeback to you!
Best Regards,
Etienne Lord
Would you be able to export your Template and send it over using the link I will send you via Private Message?
Best Regards,
Etienne Lord
i send you a private Message (TEST.rdm) :)
It doesn't seem like I received it, could you send it again using the link that was provided?
Best Regards,
Etienne Lord
I was indeed able to reproduce the issue, it seems like an issue regarding the session ID being the same. I will continue to investigate.
Best Regards,
Etienne Lord
After looking into it, the issue seems to appear when the session have information set (Host/Credentials)
I would recommend creating a Group Template while leaving your Host session and it's subconnection blank or with Variables only.
When you then create the folder structure again using the group template, simply change the information.
Best Regards,
Etienne Lord
