Move entries between Vaults?
Hello!
Is there an easy way to move entries from one Vault to another? I saved some website credentials into My Private Vault using the Browser extension and now I'd like to make them available to other users by moving them to a Folder in our shared Vault. Apart from an Export/Import I found no way to do that. Cut/Paste would be a nice for that, or simply being able to select different Vaults in the "Move" dialog
All Comments (6)
Hello Daniel,
In order for you to be able to provide some entries stored in your private vault to your users without doing an Export/Import, you would need to do the following.
1- Select the entries from your private vault that you wish to add to your main.
2- Right-Click on them
3- Select "Clipboard" -> "Copy"
4-Make sure that the "Change ID" option is checked in the "Copy Options window
5- Move to your Main Vault, select the folder in which you wish to add your entries and Right-Click on it
6- Select "Clipboard" -> "Paste"
James Lafleur
Hi James,
I tried the same procedure in our environment now. I can select the copy button in my private vault, but I can not paste it in our public vault.
Any ideas which permissions are needed to paste the object in the public vault ? In the the folder where I want to paste the object, I can create new objects manually.
Br,
Thomas
Yes it's the same for me... cannot paste the item
Tried again after the latest update... I cannot copy or paste entries in the shared Vault. It works if I login as admin, but not with normal user accounts. I can't find any related options in the Vault settings, and my user group has all permissions except Edit Permissions
OK I figured it out! You need the Import and Export permissions.
I changed it using RDM - Log in to the DPS as admin, go to Administration / System Permissions and assign it to a User Group
Thank you for the information.
That is almost right. The Paste feature requires the Import permission is System Permissions and the Add permission on the destination folder to enable it. And the Copy requires the Export permission in System Permissions and the Copy Password permission on the source folder to enable it for standard users.
Érica Poirier
