PageUp/PageDown and Copy features in MC (midnight commander) and mcedit
Resolved Implemented
On Macbook Pro. SSH session.
It would be good PageUp and PageDown buttons combination in MC (midnight commander) and mcedit (F3-view mode, F4-edit mode).
In others ssh clients: PageUp = fn+arrow up, PageUp = fn+arrow down
Next feature: Copy text in MC and MCEdit with Shift+trackpad/mouse
Thank you
All Comments (8)
Hi mantoze,
PgUp and PgDown seems to work properly on my side.
What version of RDM are you using?
Xavier Fortin
I'm using 2019.2.2.0 version.
Macbook pro 15 2019.
fn+arrow up/arrow down not working for me.
Hi mantoze,
In RDM Windows, there is multiple options to manipulate the behavior of keyboard keys (as different servers handle them differently). They are sadly missing in RDM Mac. I've created a Task to add them. When it will be done, we will inform you so you can try to change those settings and see if they resolve your issue.
Xavier Fortin
Any progress on the Shift-Mouse-Drag to select text in MCEDIT and copy to clipboard? We desperately need it here! It works in Putty but not RDM.
Hi martinwojak,
It's been a while, but looking at my reply, if I had to guess, while we did implement the first part, I think I might just have missed the one about the SHIFT + Mouse. I'll open a ticket.
Xavier Fortin
Hi again martinwojak,
I've just got in touch with the developer of the Terminal and he just confirmed that it's already supported. It uses the CTRL key instead of the SHIFT key though (as to not interfere with the current SHIFT behavior).
Xavier Fortin
Great! Thanks for that. Confirmed working! Martin.
Glad to hear it!
Do not hesitate if you have any other issues.
Xavier Fortin
