Receiving this error when attempting to connect to a session via integrated Wayk Now (as a sub-entry of RDP session):
Hi Martin,
As the error message says, unattended access requires a license. Did you already have a license configured on your client and it stopped working after the update? It currently not possible to configure the Wayk Now license within RDM, you need to install Wayk Now and configure the license with the UI, or use our Wayk Now PowerShell cmdlet to set the license without installing Wayk Now: https://www.powershellgallery.com/packages/WaykNow
Marc-André Moreau
I have had a license for a while, and it has worked up until the update:
Hello Martin
I'm sorry that some late changes in Wayk Now caused this regression in the RDM integration. This is already corrected and should follow in 2019.2.15.
Thanks and kind regards,
Richard Markievicz
This should be fixed in RDM 2019.2.15 here
https://remotedesktopmanager.com/home/download
Thanks!
In 2019.2.15.0, the first time I opened a Wayk Now sub-entry, RDM crashed. Every subsequent time after restarting RDM results in this:
