Multi Vault Search dont work
Implemented
Hi
I am currently testing the latest beta version and found that the Multi-Vault search does not work.
RDM: 2019.2.8.0
If the Multi Vault Search is activated, it does not find any results but lists all entries.
Also the Multi Vault Advanced Search does not find any more results. All entries are simply displayed
Can anyone confirm that?
Best regards
Simon
All Comments (5)
Could you tell us what version of DPS you are currently running? You can find out within RDM if you go in File > My Datasource Information
Hi Hubert
We using the lastest Version of DPS: 2019.1.20.0
Best regards
Simon
Thank you. I'm able to reproduce, we'll check to see what's happening and whether it will take an RDM/DPS update to fix the issue.
This will be fixed starting from RDM Beta 2019.2.9.0. You will not need to update your DPS instance.
Hi Hubert
I can confirm that this problem is fixed with version 2019.2.11.0 beta.
Thank you.
Best regards
Simon
Closed
