Hi Support,
When we try to connect to a RDS (admin session) server (member of a RDS cluster) we are getting a protocol error.
"Because of a protocol error, this session will be disconnected. Please try connecting to the remote computer again."
I've found the same error for RDM. (https://forum.devolutions.net/topic24664-protocol-error-for-rdp-sessions.aspx)
But it always happens, even when no other sessions are open. (and their isn't a 64bit launcher)
We allready tried to change the RDP version, but without success.
Some time, (1 out of 100 I guess,) the connection succeeds.
When using the normal RDP client to connect to the server with default settings every works fine.
Kinds regards,
Hans Vos
Hello Hans,
Which version of RDM are you using? If you are using the enterprise edition of RDM please confirm you use C:\Program Files (x86)\Devolutions\Remote Desktop Manager\RemoteDesktopManager64.exe
David Grandolfo
Hello David,
None, we are using the Launcher with the password server.
We don't use the RDM.
Kind reagards,
Hans Vos
Could you please record logs in the settings window and try to connect again on the RDP connection. After receiving the error please send us the logs at ticket@devolutions.net
David Grandolfo
Hi David,
I've reproduced the error and sent the log file to support.
Kind regards,
Hans Vos
