2019.1.15.0 SSH Shell (Shift key and mouse navigation not working)
we're discoverd that the keyboard shortcut SHIFT + any key and the mouse navigation (in the Midnight Commander for example) doesn't work any more.
Compared with 14.1.3.0 the mentioned settings works flawless (same session)
Thanks!
Min
Hi Min
Both problems are already fixed and will be available in the next version (or the one after that).
Denis Vincent
Awesome! Thanks Denis! ;)
Min
Hi Denis,
the issue with th SHIFT key is solved! Unfortunately the mouse navigation issue in mc still exists (2019.1.18.0)
On a mouse click a string like this will be written: 0;47;25M3;47;25M
Thanks!
Min
Hi Min,
I have made changes and fixes to the mouse support but I do not think they made it in 2019.1.18. It could also be another unknown application with special behaviour. I usually perform my mouse tests with htop or mc on macOS. The strings you get look like the sequence I send for mouse clicks but without the escape sequence. That is strange...
Denis Vincent
Hi Denis,
thanks for the information and the hint regarding the macOS!
I can point the issue now only to a specific distribution: CentOS - I tried it also on a Debian OS and here the mouse navigation works flawless!
Maybe this information is helpful ;)
Thanks!
Min
Thanks, it helps. But I also would like which application you are using?
Denis Vincent
I tried on both distros the mc (Midnight Commander - see my first post ;) )
Min
