Remote Access requiring SRD not offering SRP
Hi, I have been trialing Wayk Now Enterprise Version3.0.3 and successfully connected to remote computers using SRP , but randomly the connection on one computer is wanting SRD authentication, and not offering any other options in the drop down box.
I have checked all settings and can find no answer.
The bookmarks all show SRP Auto login in the Credentials list,
I managed randomly yesterday to modify / repair the installation to Login with SRP, but today it will only offer the SRD login (I don't have windows login passwords on any of my computers)
I have looked at version 3.1 but it required 3 fields, Name, Target ID & unique identifier (wasn't sure what was required in the unique identifier field)
Any ideas???
- Thanx!!!
All Comments (2)
I've transferred your topic to the Wayk Now Support forum, the Team should be able to answer your question!
Best Regards,
Etienne Lord
SRP authentication is only available when a user is currently logged in with the Wayk Now program running (the main window with the SRP password shown). Unattended access required SRD authentication, which can be done using a regular Windows account, as described in this other thread:
https://forum.devolutions.net/topic30868-wayk-and-rdm-for-ios.aspx#post123951
However, since you don't have a Windows account on the target machines, I understand why SRD with a Windows account is not suitable. We did come up with a solution in 3.0.2 where the .msi installer can create a special "wayk-admin" account authorized for Wayk Now remote connections, but that won't show up as a regular Windows account. The goal was to provide an account administrators could use for Wayk Now without having to regular a complete user account on the system.
The current way to create and set the password for the wayk-admin account is through a .msi installer option. We have a task to expose the functionality through the user interface after Wayk Now has been installed, but we didn't get a chance to work on it yet. For now, open an elevated command-prompt, and launch the .msi installation like this:
msiexec /i WaykNow-x64-3.1.0.0.msi WAYK_ADMIN_PASS=YourStrongPassword123!
If you wish to perform a silent installation with logs, it can be done like this:
msiexec /i WaykNow-x64-3.1.0.0.msi WAYK_ADMIN_PASS=YourStrongPassword123! /qn /log log.txt
Once this is done, you can create a bookmark entry with SRD credentials for the "wayk-admin" account and the associated password.
As for the unique id in the bookmark, it is an optional feature introduced in 3.1.0. Since the 6-digit ID can sometimes change, a longer, more permanent unique id can be obtained to find the target machine even if the 6-digit ID has changed. This unique id is much longer and can be obtained in the About box of Wayk Now.
Marc-André Moreau
