[SOLVED] Beta 4.9.0.0 - What's "color customization per-session" and "start/stop for dynamic logs"
Can you clarify what are the following entries appearing in the version 4.9.0.0 (August 30th 2018) Beta changelog:
•Added color customization in SSH Shell entry per-session, default checking in the options
•Added start/stop functionality for dynamic logs in SSH shell
All Comments (2)
The color customization can be found in the "terminal" tab of the SSH Shell entry, in the "display" category:
As for the dynamic logging, you need to make sure your SSH shell entry doesn't have logging enabled. Then, when running the SSH entry, you can click the following in the toolbar:
There is then another button to stop/start recording:
Thanks a lot!
