Use built-in SSH/Telnet client on a entry created for PuTTY
If an entry was created for PuTTY (with RDM for Windows), and this entry is opened on Mac, nothing happens.
Would it be possible to instead open the session using the built-in SSH/Telnet client, as if it was created as such? Thanks.
Jelle Hillen
Do you have the session setting saved in RDM or it's a Putty session?
It is saved like so:
If they need to be saved differently for this to work, we'd gladly change this, of course.
Jelle Hillen
Hi Jelle,
It actually should. But I confirm that it doesn't.
This appears to be a regression. I've found and resolved the issue.
You can expect it in an upcoming version of RDM Mac.
Xavier Fortin
Closed
