I try to refactoring a (RDP) session with a template - I select to keep the information section and custom image - but this would be overwritten from the template. So after applying the template the information section is gone and instead of the custom session image the default one is applied.
Min
We have been able to reproduce your issue and a ticket has been submitted to our engineering department.
Thank you for reporting this!
Marc Beauséjour
Wow - that was fast! Thank you Mark! :)
Min
Hello Min,
Sorry about the delay, this has been fixed internally (for both the custom image and the informations) and it will be available in the next RDM build.
Hi Hubert,
no problem - as always thank you very much ;)
Min
Hi again,
we are on 14.0.6.0 and the Credentials get lost (also when the Checkbox for this setting is enbaled) when we apply the template
We tried it on a Web Browser (http/https) session
Thanks!
Min
Thanks Min, we'll take a look.
