Datasource does not load via Webdav (HTTPS, Nextcloud 13.02)
stronzo
Disabled
Hello there,
as the Company where I am employed started to use RDM, i wanted to give RDM for Android a try on my private device, too.
However, wehn I try to load a datasource from my private nextcloud, it starts to load and after a few seconds, without any error message, Displays "not connected".
Connectivity of the app is NOT blocked by any Firewall or privacy tool like XPosed + XPrivacy
Server is a Nextcloud 13.02 instance with SSL-Cert provided by LetsEncrypt, running on Ubuntu LTS 16.04, other apps can connect from Windows/Linux/Android machines.
LOCAL INFO/SETTINGS:
Android 6.01 on Galaxy Note 4 Stock
RDM for Android Version: 4.11
Settings for the Datasource
Host: Domainname.com
Port: 443
Username: myusername
Passwort: mypassword
Directory: /remote/php/webdav/subdir1/subdir2/
Filename: filename.xml
The subdirs are for my internal structure, it does not matter if I use that path or the root Directory.
The according log for the last failed attempt:
Can you probably provide any advice?
thanks in advance
S.
All Comments (7)
Are you able to connect to the WebDav data source via RDM Windows?
Nicolas Dufour
stronzo
Disabled
Thanks for the quick Reply!
Just tried it from one of my office machines (don't have an Enterprise license or trial Version at home, Webdav is an Enterprise feature in the desktop version if I remember it correctly?),
Connection succeeded and the content of the datasource was displayed correctly (it is not in the same network, but that should not make a difference as I can ping the Server from both networks as well as connect to the Nextcloud instance in the browser)
Used the same settings, with the only difference being that the Windows Version has an explicit checkbox for "SSL", and I enabled that option.
Is there a paid/Enterprise version for the Android app, too? I did not see one in the store, do I Need an Enterprise license for Webdav?
Yes, it is true, we do not have the SSL option on the WebDav data source.
This could be the reason why it is not working on Android.
Can you try to create a WebDav session (not a data source) on windows and open it?
If it works, can you try to create a WebDav session on Android an open it?
We would like to know if you WebDav session works ok on Android.
Nicolas Dufour
Maybe I am a bit blind and/or dull today, but my RDM app does not show anything like a verbose Level or a SSL checkbox?
I am pretty sure that I have the latest Version Google Play offers, and when I create a new Webdav source the forms look like this:
Hi Seb,
You are right. Please refer to my previous post. I first thought we had the option and I then re-posted a few minutes later when I realized
the option wasn't there. You saw and replied to my first post. Sorry for that.
As I mentioned in my previous post, can you try to open a WebDav session (just to see if it works ok with your setup).
We are currently working on a new release, we will try to add the ssl option to the WebDav data source.
Nicolas Dufour
Hey Nicolas,
good to hear that you are on it.
I tried 3 different SSL secured Webdav Connections to be sure (my Server, a GMX account and agerman telekom account), all of them work with RDM for Windows, None of them works with the app, so using LetsEncrypt on my machine can't be the culprit.
I guess the SSL bit is in deed what makes the difference.
I also reproduced the issue with RDM for Android 3.5, the only difference is that the old Version actually throws the exception while 4.11 has it silent.
Quick follow up:
Tickiing the new SSL checkbox in the new PlayStore update solved the problem.
Thanks and keep up the good work
Seb
