13.0.12.0 Sorting for Folder and Entries
only from curiosity - starting with 13.0.12.0 the sorting has changed - on previous versions the sorting was folder and then entries. now it is reversed - first entries and then folders.
Just for interest - is there a option to set the order back to the old model?
Thanks! ;)
Min
All Comments (12)
Thank you for posting this!
I think I recreated the issue but just to be sure, could you please attach a video showing us the issue?
I just want to confirm my findings.
Marc Beauséjour
After further testing, I think this might have been an issue with the entries themselves.
Like you, I had 2 entries right under the Root Folder but after deleting/restoring them in my SQL Server Data Source, the issue seems to have disappeared.
Could you please confirm?
Marc Beauséjour
Hi Mark,
can't confirm the behavoiur - I have 3 different repositories and the sorting issue is on all present. I tried the version history and restored a older config from the session - also the mentioned method with delete and restore - but both had no impact on the sorting view.
Reagrds,
Min
Could you please create an XML Data Source with 13.0.8.0 and use it with 13.0.12.0 to see if you have the same issues?
Marc Beauséjour
Hi Mark,
yes exactly the same behaviour - attached a screenshot. Also an export from the configured tree
Min
Test-13.8&13.12.rdm
Could you please change the sort order by clicking on the Name column?
Marc Beauséjour
Ok, I have enabled (in 13.0.12) File => Options => User Interface => Tree view => Allow tree view column sorting.
But, in 13.0.8 this option was not enabed, and if you sort the entries in 13.0.12 that folder appears at first, it isn't sorted alphabetical
Min
I've compared your file with both versions and if I sort alphabetically for both, I get a consistent behavior;
Could you please check if the sorting is set alphabetically for both versions?
Marc Beauséjour
Hi Mark,
yes thats correct, but the initial question was, if there is an option to get back the original order before version 13.0.12.
It was first folders and then entries (in alphabetical order) - if you change the order to this scenario, on your mentioned screenhsot you will see that the alphabetical order are not working.
As I previous said, in 13.0.8 the mentioned sort option was never enabled. Something with 13.0.12 has changed the sort order.
Min
Thank you for your reply.
We'll continue looking but we might have to disable the tree view sorting option to make it work as intended.
Marc Beauséjour
Hi Mark,
thank you very much for your investigation! In the past I never had checked the option "Allow tree view column sorting" so this would be fine for me :)
The main question is can you reproduce the sort behaviour issue and what was changed in the beta version - and (in best case) add an option to get back the old sort order ;)
But again, thank you very much for your investigation and sorry for annoying you with such unimportant details :worship:
Min
I have discovered that the behavior we saw is not the one intended so indeed I'm recreating this issue easily.
Marc Beauséjour
