Problem with MariaDB : sometimes no connections
i have another Problem. Last week i switched from WebDAV to MariaDB. Now i have the Problem that i sometimes have no connections. When i click host test and schema test, all is fine. but my connections from the db aren't appearing :(
Oliver
All Comments (2)
Could you try Ctrl+Refresh or Ctrl+F5 to see if a full refresh fixes the problem?
Hello David,
thanks. It looks like it works =)
Oliver
