currently i test and play a bit with the RDM beta and i think i found a bug. I can't delete any entry. In the Application Log appears only this Message:
[06.10.2017 11:05:41 - 12.9.4.0 - 64-bit] Fehler Still: Error - FAIL
Greetings
Bootscreen
What data source type do you use? Is it SQL, DVLS or an Xml?
hy, it's a WebDAV connection to my Nextcloud Server
I will assign this to one of our dev for investigation.
I was able to reproduce your issue, a ticket has been sent to the engineering team.
Alexandre Roy
