Guys, after the fix implemented on version 12, the issue reported under https://forum.devolutions.net/messages.aspx?TopicID=26911 has been fixed, yet I've detected now that if a password contains a '+' the password will be trunkated at the '+' sign.
I'm running 12.0.2.0.
Could you try to execute the macro in Notepad with the password in clear text in the macro and with the $PASSWORD$ variable.
Let us know the results of both tests.
Hello Jean-François, thanks for the prompt reply! Just tried using a plain text password "1234+5678" in the Macro field, and print it to a note pad as requested. It only printed "1234".
Hope this helps.
Hernán
I am not able to reproduce your issue.
Could you post some print screens of the configuration of your session. This may help me to try to reproduce.
Hello, yes, please find attached a screenshot of the credential and the macro configuration.
I have been able to reproduce your issue.
A ticket has been opened to our engineering department.
This has been fixed internally and will be available in the next beta version of RDM 12.
