8.0.24 does not integrate with PVM
8.0.24 does not integrate with PVM...
I get a pop up saying that RDM is trying to open PVM.
Are you using Password Vault Manager credential entries?
http://help.remotedesktopmanager.com/index.html?credentials_passwordvaultmanager.htm
Do you get an error message? Could you post a screen shot?
Stéfane Lavergne
I use PVM credentials via the repository (but tried it as embedded and got the same results)
Attached are screen shots...
restart solved the problem...
